HenrikDK
Sep 10, 2017Follower
Aircard 790 freeze
Hi please help me. My aircard freeze during startup amd never come further that the purple startup screen. Nothing help. Only thing to do to turn off is to pull out the battery, but it continue to...
DarrenM
Sep 13, 2017Sr. NETGEAR Moderator
Hello HenrickDK
If you have tried a factory reset and it does not work I would suggest taking it back to where you bought it. Or contacting Netgear support.
DarrenM
