piciu91's avatar
piciu91
Aircard 790s - Firmware not working
Good evening guys!
I have a problem when I try to search for new firmwares of my AirCard 790S.
I haven't got the BigPond one, but a beta tester's one.
The following message appears(I'm translating from Italian, so maybe not literaly):
There was a problem during the upgrade of the device . Please try again later .
What can I do? Do you know where can i found and download manually firmwares?
Thanks!
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello piciu91
    You will have to contact Bigpond about the firmware.
    DarrenM
  • I haven't got the BigPond one, but a beta tester's one. I have to contact bigpond anyway?
    • DarrenM's avatar
      DarrenM
      Hello piciu91
      Yes Netgear does not have any firmware for direct  download for the 790s Bigpond you will have to contact there support for help on this.
      DarrenM
