DangerMouseUK
Apr 13, 2016Aspirant
Aircard 790S Not Working @ Category 6 Speeds
Hi there,
Using the Aircard 790 EUS or S - the UK unlocked retail version, I cannot get Category 6 speeds at all.
The device will only use one 20mhz band and will not connect to another 20mhz band at all.
In the exact same location with the exact same sim card inserted in an iPhone 6S Plus, I will get carrier aggregation and 150mbit.
The Aircard will max out at about 90mbit or so.
Can this be looked into or does anyone else have the same problem ? I opened a support ticket but it just went nowhere fast.
The provider is EE UK.
Thanks
DM
1 Reply
- DangerMouseUKAspirant
No one ?
