stigarius
Jul 06, 2017Aspirant
AirCard 790S Status data usage
Cant seem to get the counter started on the device (router). Counter works in smartphone app for session in use but will not udate days left or data usage on the router. (PRI version: 01.06) (Web A...
- Jul 13, 2017
Thank you for sugestion. Actually i just got an firmware update (5 minutes ago) and now everything works as it should.
DarrenM
Jul 13, 2017Sr. NETGEAR Moderator
Hello stigarius
I would suggest using your ISP data counter as it would be the most accurate for what you are using.
DarrenM
stigarius
Jul 13, 2017Aspirant
- lochan3840Aug 06, 2017Aspirant
Excuse me
I also have a similar situation in the main picture can not show the data where can I get a software update can you help me get it?
