stigarius's avatar
stigarius
AirCard 790S Status data usage
Cant seem to get the counter started on the device (router). Counter works in smartphone app for session in use but will not udate days left or data usage on the router. (PRI version: 01.06) (Web A...
  • stigarius's avatar
    stigarius
    Jul 13, 2017
    Thank you for sugestion. Actually i just got an firmware update (5 minutes ago) and now everything works as it should.
