WebDiver's avatar
Aug 18, 2016
AirCard 810S Mobile Hotspot Carrier Aggregation is not showing all bands
Hello,
simply question :) When my device AirCard 810S cat. 9 is in range of LTE+  it means, that is connected minimum to 2 or 3 bands (frequencies), right?
I check Download and Upload and I can see, that's true - connection is definitely speeding up whithin LTE+.
BUT when I checked Status Details, the device always shows me only one band. So, I cannot check, what frequencies my device is currently aggregating.
So, my question:
What to do, to see on the AC810S screen all bands, which are currently aggregating by my device been in range of LTE+ ?
Thank you for the answer.
  • You cannot determine aggregated frequencies from AC810 4G Status details. It shows only one band and there is nothing wrong with that. AC810 package label shows supported 3CA combinations and you have to get that nearest base station frequency data from your cell operator if you do not already know the details.
    in principle, the device selects the best performance settings available in the base station, if everything is properly setup and configured(CPE, base station and subscription).
