chriswal's avatar
chriswal
Aircard 810s Retail new Firmware 23112817
Hi,
Today i got a new firmware version 23112817 OTA for my Aircard 810s.
Dont need to load different drivers to get it working ..its running with the standard drivers  ..on Windows 10
runs without battery when connected to the USB Port .. at least on my PC
Thumbs up
Release Notes would be appreciated
    • chriswal's avatar
      chriswal
      It was to early to be happy.. after some time the programs using the internet connections got locked up ..and locked up again the whole system ..after changing to USB RNDIS6 Drivers it works again ...so not solved with the new Firmware
      And the Device works in thethering mode without battery only if you disable wifi ..if there is a wifi device transmitting data the device resets ..
    • pegasus88's avatar
      pegasus88
      I've been trying to update my Aircard 810S, but I ether get the following error:
      Update Error: There was a problem updating your device.  Please try again later.
      Or the downloading bar scrolls forever.
      Can someone help?
      My Current Firmware Version:
      NTG9X40C_11.14.08.12
      Build Date: 2016/09/14
