mgull
Jun 25, 2017Aspirant
Aircard 810s (Telstra) + Asus Rt-AC68U slow or no internet
I've been running my Telstra aircard 810s tethered to an Asus RT-AC68u router for 6 months now and about half the time, the internet is slow or very slow to respond. My home internet is Telstra 4GX. ...
compspy
Aug 30, 2017Aspirant
did you endup work out what the problems was?
mgull
Compspy,
I took the Aircard 810s off the Asus router and ran the Aircard 810s as my wifi for home. It still had periods of being slow or no internet for a week or so, then has come good. Has been good for a few months now. No where near as secure as the Asus router :(
I haven't had the time to do a factory reset and update on the Asus router and then reconnect the Aircard 810s.
Hope this helps.
- compspyAug 30, 2017Aspirant
it's seem to be there is a problems for aircard 810s or aircard 790s with asus rt-ac68u.
Alot of https page not fully load or not loading at all, i dont know why, maybe there is a problem with MTU size.
It seem to working fine with Siera 320u.
- TeeJay74Sep 01, 2017Virtuoso
Real problem is asus rt-ac68u. It does not support modern 4G USB devices properly. Please use another router. For example Smart Cradle and Dovado Pro AC do fine with AC810.
- mgullSep 03, 2017Aspirant
Thanks. I checked with Asus before trying this new modem and they assured me that it would be ok. Maybe that's the real problem?
Compspy, yes, my Sierra 320U worked a treat too.
