dod_88
Nov 28, 2016Follower
Aircard 810s
Hi
I have some questions about the 810s i bought.
The main features works fine. But there are some points i don't get...
1. Can you hide the password from the Device? You can hide it from the main screen, but if you go to the wlan menu its visible... that's not really smart.
2. It seems that i cannot turn USB-Tethering off... I turned it off, then i connected it to the PC, and it still opens a connection with it on the pc. Can i turn it off somehow that it wont show up on my pc? I just want to load it over USB.
3. Can i turn off SMS? I don't need to get the sms on this device...
Thanks in advance
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello dod_88
1. I do not see a way to hide that.
2.It should be off when you disable that I will have to look into that issue
3. I see no options to turn off SMS
DarrenM
