CFalzon
Jun 15, 2017Aspirant
Aircard AC810 with with Smart cradle - cannot get good throughput on 4G 3 CA
I cannot get more than 230Mbps whereas I should be getting about 400 to 450Mbps.
I have 4G+ signal three bands of 20MHz with carrier aggregation, 2x2 MIMO and 64QAM.
Problem is not with signal or the 4G+ network since I get 400-420 Mbps with a Samsung 4G+ smartphone in the same position.
Shoudl I ask for a warranty replacement or is this just some configuration I need to do to make it work properly?
- bb4meAspirant
It wont get any better, it is rubbish. The 4gx works better on its own. and dont bother with external aerials, they make no difference
- CFalzonAspirant
Did you manage to get better throughputs with the 4GX on its own, how much better?
I tried it on its own as well but still couldn't get better results, but then I could of course only use WiFi or USB which I don;t know if it can handle that sort of throughputs.
- bb4meAspirant
The throuput was doubled, but i cant remember the figures, but of more importance to me was that the wifi range was also doubled. i put the cradle back in its box and out in the shed, who's got time to waste trying to get it fixed?
