Miss
Apr 07, 2018Aspirant
Aircard ac810s Keeps Rebooting
We can be using the Wi-Fi and the unit will reset / restart while using. Does not matter if on dock station or not In addition to this will just loose connection (without shutting down) Telstra hav...
Miss
Apr 13, 2018Aspirant
Yes mostly, but we take away on weekends where is not plugged in. Does the same.
Generally though in the booster craddle
JasonN
Apr 16, 2018NETGEAR Employee Retired
Hi Miss,
Is your device up-to-date with the most current firmware and have you done a factory reset on it?
Please let me know. :]
- Jason N
- MissApr 16, 2018AspirantYes have done all that.
Read through posts on another site and they suggested the factory reset but that didn't work- JasonNApr 17, 2018NETGEAR Employee Retired
Hi Miss,
Please contact support and they will be able to help you with the issue.http://www.netgear.com/support/contact.aspx
- Jason N
