DLS1
Nov 07, 2016Follower
Aircard Can't Shutdown
My Aircard 810S (Telstra Wi-Fi 4GX Advance) cannot be shutdown after charging. I can request shutdown, but it just goes back to the message "Fully charged, please disconnect from power" and will not...
Demo350
Feb 04, 2017Aspirant
I have exactly the same problem. The device works well and shuts down as it should between charges, but after charging the only way to shut it down is to remove the battery. If it was a hardware problem it would be doing it all the time, wouldn't it? The problem started after the most recent, and latest update. A solution would be greatfully received as the Australian Telstra Crowd Support seems unable to offer advice.
- DarrenMFeb 07, 2017Sr. NETGEAR Moderator
I have been tracking issues with the 810s and been sending this info over to our engineers for them to work on fixing in firmware I will add this to the list of issues.
DarrenM
- kh28Feb 20, 2017Aspirant
Thank you DarrenM: I am looking forward to a solution. In a previous post I said I had solved the problem but this was not correct. Removing and reinserting the battery and card allows shutdown only until the unit is put on charge. After charging the battery and card must be removed and reinsereted again. I have always held NETGEAR in high regard and was disappointed when this Aircard did not work properly.
