Gavin_Wood's avatar
Gavin_Wood
Follower
Nov 30, 2016
Aircard Can't Shutdown
My Aircard 810S wont shutdown after charging - i.e., the homescreen is not longer visible, but the orange light continues to flick - as if it is 'sleep' mode.
The nett effect is that it discharges it's avaialbe power much quicker than normally.
Does anyone have any idea how to sort this?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Gavin_wood
    Have you pulled the battery and made sure the firmware is up to date.
    DarrenM
