bigdickau
Feb 02, 2014Follower
aircard hub and aircard 760S
Hi All i done a search on this site for some help about the aircard hub and aircard 760S. no luck. so here we go i have a server with windows server 2008 R2 and running xampp. I have a bigpo...
apac_se
Feb 16, 2015Apprentice
Hi Richard,
best way to do this is to setup the DMZ on the AirCard 760S to point to 192.168.2.2 then setup a NAT rule for the server IP on the AirCard Hub. You could also just place the server IP in DMZ of the hub but this may not be secure.
You can use the guide in the following link for reference: https://dl.dropboxusercontent.com/u/53852158/OpenVPN%20Server%20setup%20with%20AirCard%20760S%20and%20AirCard%20Hub%20solution.pdf
