UltraFusion
Jun 06, 2017Aspirant
Aircard SD Memory Access from Android
I use an Aircard to get Internet access - works great - and I have put an SD mem chip in the Aircard and can (wifi) access the files on the chip from my PC without any problems. I am also using ...
DarrenM
Jun 09, 2017Sr. NETGEAR Moderator
Hello Ultrafusion
You may want to check pages 31 and 32.
http://www.downloads.netgear.com/files/aircard/4111813_Rogers%20AirCard%20763S%20User%20Guide_r1.pdf
DarrenM
- UltraFusionJun 10, 2017Aspirant
Yeah thanks - have already scutinized the manual but it comes up short on suggesting what entries I'd need to make the connections ...
