archspangler's avatar
Oct 01, 2016
Aircard U340 not working on Apple MacOS Sierra
I upgraded my MacBook Pro to Apple Sierra macOS 10.12 and I can no longer use my 340U device.  I have tried the AT&T All Access connection manager and also the Netgear Watcher software.  Both of the software application do not detect the device plugged in.  I know the device is working because I can plug it into a PC and it works fine.
What is the trick to getting this AirCard 340U to work with macOS Sierra?  Any help would be appreciated greatly; because I am just about ready to throw this AirCard against the wall... grrrr.
-Archie
  • AirWatch reported no device found, despite the AirCard 340U being connected to the Macbook Pro Retina's USB port (left side or right side).
    • egberts's avatar
      egberts
      Guide
      Executing the equivalent of lsusb command which is system_profiler SPUSBDataType shows:
          USB 3.0 Bus:
            Host Controller Driver: AppleUSBXHCIPPT
            PCI Device ID: 0x1e31
            PCI Revision ID: 0x0004
            PCI Vendor ID: 0x8086
              AirCard 340U:
                Product ID: 0x9051
                Vendor ID: 0x1199  (Sierra Wireless Inc.)
                Version: 0.06
                Serial Number: 013323002244540
                Speed: Up to 480 Mb/sec
                Manufacturer: Sierra Wireless, Incorporated
                Location ID: 0x14100000 / 2
                Current Available (mA): 500
                Current Required (mA): 500
                Extra Operating Current (mA): 0
      • egberts's avatar
        egberts
        Guide
        Looks like the El Capitan driver doesn't work for the Sierra (10.12) release anymore.
  • I'm also having trouble under MacOS Sierra.  I'm using a Sprint AirCard 341U.  The modem does not show up.
    • egberts's avatar
      egberts
      Guide
      I'm taking a guess that this also may apply toward Spring HotSpot 341U device as well, does it PRJill?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Archspandler
    Did you make sure when using the aircard watcher that all the ATT software was shut down?
    DarrenM
    • Yes, I made sure that all the AT&T All Access software and driivers were removed.
