GeorgiePorgie
Jul 27, 2017Aspirant
AirCard Watcher App Taskbar Pop-ups
Hi Folks, Two simple issues I hope you can help me with, the first being unbelievably frustrating trying to contact Netgear support by email. I've got an AirCard 309 with a 15 digit Serial Number...
DarrenM
Aug 03, 2017Sr. NETGEAR Moderator
Hello GeorgiePorgie
Have you tried to reinstall the aircard watcher app? also pm me the serial number and I will try and figure out why you can not register it.
DarrenM
GeorgiePorgie
Aug 05, 2017Aspirant
DarrenM wrote:Hello GeorgiePorgie
DarrenM
Hi Darren,
Yes, I've uninstalled the Watcher App multiple times and rebooted the pc after each uninstall before installing again without change :-(
The serial number is 355389030502387. Please ignore the Model number given in the Model line of this thread as it autochooses from the limited dropdown list and won't allow corrections. The actual Model is AirCard 309 and it has DNA on the front of the gadget.
Thanks for your help and have a great weekend.
George
