ChrisHarding's avatar
ChrisHarding
Antenna plugs for Nighthawk M2
Hi Guys  We livestream weddings and I have two M2's each with a different carrier as sometimes some cell towers are closer than others.   I use a LPDA antenna on a 4m stand in most cases but fing that the tiny TS9 plugs tend to get loose and you end up squeezing them to make them tighter and , of course, enentually they break!!!  To solve this I use a TS to SMA adaper in the primary antenna port and I have added a dab of epoxy adhesive to keep it in place.   My question is IF i am in an area with a signal stong enough to use just the internal Nighthawk antennas will the fact that I have the adapter plugged into the port (but open circuit (so nothing is plugged into it)) turn off the internal antennas ???   Here I'm assuming that once you plug in an antenna to the adapter it will not use the internal antennas in the unit but will they still work if I just have the adapters plugged in???
  • On original TS-9 antenna port, once you have any antenna connector plugged, the built-in antenna will be disconnected regardless if you have external antenna plugged along with that connector.
    • ChrisHarding's avatar
      ChrisHarding
      Thanks so much William
      Darn!  I was hoping the unit wouldn't see the the adapter as it's just an open circuit device with nothing plugged into it but obviously not ..I have actually used epoxy to keep the TS9-SMA adapters in place so instead of trying to chip the adhesive away would it be a better bet to just screw in two SMA 4G antennas into the adapters if I don't want to use my big LPDA antenna (like in an indoor environment)    Your help is much appreciated!!
