CFalzon
Jun 09, 2017Aspirant
Anyone managed to get more than about 230Mbps from an Aircard AC810 on 4G ?
I have an Aircard AC810 with the DC112A cradle and I'm struggling to get the throughput I expect from it. At best I can get about 220Mbps whereas I should be getting over 400. The device is conn...
TeeJay74
Jun 23, 2017Virtuoso
Have you tried AC810 factory reset ? It would not be a surprise if it would fix the problem.
