Johnelove's avatar
Johnelove
Follower
Oct 05, 2017
APN settings for NYC based T-Mobile
Hi, I have the LB1120 LTE router. I 'am using a T-Mobile sim card and I am in the NYC area. Speed tests have been erratic. Mostly I get 56k speeds. However occasionally when I reset the router I will get 5mb per second download speeds, which would be acceptable if consistent. I am using the following APN settings. Name T-Mobile US LTE APN fast.t-mobile.com Authentication None PDP IPV4V6 PDP Roaming IPV4V6 If anyone has any better settings for T-Mobile sim cards or further advanced settings, I would greatly appreciate the input. Thanks
1 Reply
  • I just used IP4 on both. Or IPv6 on roaming.
    See if that will help you out.
    They are the settings I have on my phone, as well. It should work for you without a hitch.
    Let me know!
