asddean
Aug 03, 2017Follower
assign a static ip address to my computer from MR1100
I have had a look through lots of messages on the board but cannot seem to find the answers that i am looking for. I have just purchased the Nighthawk and want to assign a static IP address to my pr...
antinode
Aug 03, 2017Guru
I know nothing about an MR1100, but I skimmed through the manual:
http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf
and didn't see anything helpful. The closest thing I found was on page
81, "How do I find a device's MAC address?":
You must know the MAC address for a device when you are doing the
following:
o Assigning an IP address based on a MAC address (when using DHCP)
So, you know that you'd need the MAC address of the device to do what
you want, but there seems to be no way actually to do it. Other than
running a (better) DHCP server on your laptop, or waiting for Netgear to
provide more capable firmware for the MR1100, I don't see any good
possibilities. (Shop more carefully next time?)
Have you tried opening a support case with Netgear?
- MicWAug 06, 2017LuminaryThe DHCP server that is part of the M1 is very basic and is not able to allocate static IP's. If you need to do this then I would recommend disabling the M1 DHCP server and run DHCP service from another device.Other then that you would have to set IP's manually at each device you want static
