CountryGaming's avatar
Dec 13, 2017
Att NightHawk M1 getting below average upload speeds
My NightHawk m1 has been getting above average download for my rural area, the usual on my NG unite Explore being 15 to 20 mbs and has went up to 25 to 35 mbs. BUT the upload speed is cut in half, on the explore I was getting 4 to 5 mbs upload and the NightHawk is only getting 2 to 3 mbs. Using the same bands, the same type of Access Points and I'm still getting the upload drop.
Anyone experience this and maybe have a solution?
  • This is just a guess, so I may be wrong: uploads rely on transmission from the router to the mast, so the design of the antenna(s) in the router is a key factor. It's possible that the antenna(s) in your other router are more capable of transmitting a good signal back to the mast. The small size of the M1 probably has an impact on its transmission capabilities. This is apparent when one checks the range of the 2 Wi-Fi bands - they have less reach than a larger router with external antennas.
    In order to increase the signal strength received by the M1, I've attached an outdoor Poynting 4G-XPOL-A0001 Cross Polarised Omni LTE antenna to the M1 via a couple of short SMA to TS-9 pigtail adapter leads. I now have 5 bars of reception whereas without it I only had 2 to 3 bars. No doubt this outdoor antenna has also improved my upload speeds.
    I'm in a rural location and the mast that I'm connecting to wouldn't offer the 4x4 MIMO transmissions that are available in some cities, so I don't think I'm curtailing my possible download speeds by using this outdoor antenna. However, my guess is that attaching an external antenna of this type to the M1 may over-ride or impact the 4 antennas built into the M1 for 4x4 MIMO transmission, so this needs to be considered.
    • CountryGaming's avatar
      CountryGaming
      This could be it, I'm in a rural location as well and have ATT which I think they're just now rolling out 4x4 MiMo so I don't think I'll be getting the benefit for awhile.
      I just purchased a Netgear MiMo dual ts9 antenna from Amazon so I'll be 4x4 ready when it does make it out here and I think if that's the issue my results should improve.
      Thanks for the input, I greatly appreciate it.
      • UK-based's avatar
        UK-based
        Luminary
        You're welcome. It would be good to hear if your new Netgear antenna improves your upload speeds.
