Jakurtis
Feb 27, 2018Aspirant
AT&T Nighthawk M1 Internet Issue When Connected to Router
So I recently got a nighawk m1 with an unlimited plus plan through at&t. Hotspot works great, but i need more range for more devices. Problem is, when I plug it into my netgear router via Ethernet, co...
michaelkenward
Feb 28, 2018Guru - Experienced User
The MR1100 is a modem/router. Connect it to another router and you could experience address clashes.
It might be a good idea to put your router in access point mode. Not knowing which router you own, I can't aim you at the manual for it.
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
