Digdugg88
Oct 30, 2017Aspirant
AT&T Nighthawk M1 Issues - Using as Modem with Google OnHub Router connected to Ethernet
Hello All, I recently purchased the newly released Nighthawk M1 from AT&T (https://www.att.com/devices/netgear/nighthawk-lte-mobile-hotspot-router.html#sku=sku8550255). I am having some odd issu...
- Nov 02, 2017
What I ultimantly ended up finding is that - in my case - I have to leave the IP Passthrough off and the DCHP enabled on both the OnHub and the Nighthawk. In this config, everyhting seems to be working fine.
Odd - but it works :-)
argondick
Nov 02, 2017Tutor
I have the same question about connecting it to an. Apple Airport Extreme. I too am also seeing similar issues.
I did some research on the internet and discovered that this device will occassionally put the ethernet jack to sleep and conserve power. It was a known issue and supposedly fixed with a past firmware update, but maybe not?
The issues I'm currently seeing is constant power-cycling while the battery is out (but plugged into the included power adapter) and connected via the ethernet jack. On a Win7 PC it happens maybe 1-2 every 8 hours. On a Mac running High Sierra, it occurs almost every 2 minutes. Very frustrating!
I would love to know if anyone has used this as a modem only and the steps involved in making that happen. I've turned off DHCP and enabled IP Passthrough, connected it to the Airport Extreme via ethernet and have had it plugged into the power adapter without the battery. With the power cycling, its incredibly difficult to troubleshoot.
MicW
Nov 02, 2017Luminary
It should work in the configuration you described. The latest firmware ( NTG9X50C_10.16.04.04) is supposed to fix the ethernet going to sleep. I run mine for 16 hours a day with no issue via the ethernet port. One thing though, is the included power adaptor is not really fit for purpose . The manual actually recommends buying another adaptor with "Quick Charge 2.0 technology" (at least 1.5 amps) to run it from.
- Digdugg88Nov 02, 2017Aspirant
