Digdugg88
Oct 30, 2017Aspirant
AT&T Nighthawk M1 Issues - Using as Modem with Google OnHub Router connected to Ethernet
Hello All, I recently purchased the newly released Nighthawk M1 from AT&T (https://www.att.com/devices/netgear/nighthawk-lte-mobile-hotspot-router.html#sku=sku8550255). I am having some odd issu...
- Nov 02, 2017
What I ultimantly ended up finding is that - in my case - I have to leave the IP Passthrough off and the DCHP enabled on both the OnHub and the Nighthawk. In this config, everyhting seems to be working fine.
Odd - but it works :-)
MicW
Nov 02, 2017Luminary
It should work in the configuration you described. The latest firmware ( NTG9X50C_10.16.04.04) is supposed to fix the ethernet going to sleep. I run mine for 16 hours a day with no issue via the ethernet port. One thing though, is the included power adaptor is not really fit for purpose . The manual actually recommends buying another adaptor with "Quick Charge 2.0 technology" (at least 1.5 amps) to run it from.
Digdugg88
Nov 02, 2017Aspirant
