nickds's avatar
nickds
Follower
Nov 09, 2015
AT&T Unite AirCard 770S Unlocked
Good afternoon. I got AT&T to generate a MEP unlock code for my AirCard 770S. I unlocked the device and have since put a T-Mobile USA SIM card in. I have added a new Profile with the APN for T-Mobile but unfortunately my device never seems to change from Edge to 4G/LTE even though I know I am in areas that have good 4G service.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello nickds
    Have you tested the speeds to see maybe that you are getting 4g/LTE even though it dosnt say so?
    DarrenM
  • I got netgear aircard 770s n i need hlep i want to know mep unlock code n my imel: 013324003586400 fsn: EJ329603110210 sku: 65396
    • DarrenM's avatar
      DarrenM
      Hello frikalinkgh
      you will have to contact your service provider to get that code.
      DarrenM
