zhanex3's avatar
zhanex3
Novice
Dec 19, 2014
At&t unite pro - Network Selection mode
When you go to Settings -> Mobile Broadband -> Preferences, there are 3 options:
Int'l Roaming : Off On
Network Mode: Auto(Default), LTE Only, 4G Only
Network selection mode: Auto
What is Network selection mode and how do I enable being able to change it? I'm assuming it lets me select the Bands I want the hotspot to use (such as LTE BAND 4 for aws)
  • Network selection mode allows you to scan a list of mobile carriers in that location. This is to allow a user to choose the carrier of choice if device does not automatically pick it up. This feature is mainly used when roaming internationally.
  • The Network Mode option allows you to choose the band. Either LTE only or 3G only bands.
