allenrose's avatar
allenrose
Follower
Sep 02, 2015
ATT Unite Pro (781S) not accepting password after sleep
I have a new 781S with a renamed and not-broadcast SSID, but kept the factory password. When the hotspot enters sleep mode, I am not able to reconnect from my Mac or Windows 7 machine using the same password after it is woken up. I have to restart the hotspot to be able to reconnect. I would like to have the thing sleep when possible to save battery, but will set it to never sleep if there isn't a solution to my problem.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Aleenrose
    Is this happening on both the 2.4 and 5.0 ghz bands? I would try to change the wireless security type and see if this is the issue on all of them. Also I would tell your PCs to for get the network to erase the wireless settings from the past connections. Let me know if changing the security type does anything.
    DarrenM
