Orgbrat
Nov 03, 2015Aspirant
AT&T Unite Pro and Surface Book Wifi Issues
I have a new Surface Book i7/16GB/512GB laptop and I also own a AT&T Unite Pro ( Netgear ) wifi hotspot that I have used with my Surface Pro 2 for almost a year with no issues. With the new Surface B...
- Nov 06, 2015
Hi Darren,
The solution for this issue was posted on Microsoft's Surface Book forum here. But it does seem to fix the problem
Seems to be a Windows 10 Marvell Wifi driver issue.
if this does not work, change the parameter back.
1.Press Windows button. Search for regedit. Open it
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\mrvlpcie8897
3. Find the item labeled “TXAMSDU”. Double tap and modify the value from 1 to 0
4. Restart the machine
Cause:
Microsoft states there a known issue with the .41 Marvell driver that results in low throughput with specific access points. The issue is specific to MAC layer aggregation (AMSDU over AMPDU) and only impacts a small subset of access points. They state they are working on a fix for an upcoming update. Until the fix is available, please update the registry key setting to work around this issue
Orgbrat
Orgbrat
Nov 06, 2015Aspirant
Hi Darren,
Cause:
Orgbrat
greenbergm0625
Nov 30, 2015Aspirant
I have the same issue with a 781s and a Surface Pro4. Only the 4 model - the V3 works fine - both on W10.
Will try this fix and see if it works
