Johnr3524
Aug 16, 2018Follower
Auto start on power on - Auto off with power off
I'm interested in using my MR1100 from AT&T in my car. I would like some advice, as I was hoping to do one of two things:
In mycase, I expect the unit to be plugged into a switched (by key) US...
JSchnee21
Aug 22, 2018Virtuoso
Hello Johnr3524,
The MR1100 will happily turn on automatically when power is supplied to the USB-C connector. Personally, I find this behavior really annoying when I'm trying to charge it at home and I don't want it's Wifi conflicting with my home Wifi.
BUT, it will not turn off automatically. It will run until the battery goes dead.
BUT, you can run it without the battery which should do what you are looking for. You could also leave the battery in but set the Standby time to go to sleep when no clients are connected. I not sure if turning power back on will wake it up or not. You might have to press the multifunction button to wake it up.
-Jonathan
