TimeFramed
Dec 19, 2019Follower
Automatic "failover" to cellular when wired data limit approached
So, I have a somewhat backwards scenario. My wired ISP has a 1TB limit, and my wireless is unlimited.
Is there a way I can have the LB2120 monitor the *wired* data usage, and when it hits, say, 90 or 95% of the limit, it automatically switches to cellular-only util the billing cycle date?
I get an 85%-used warning from my ISP, so I can manually enable wireless-only at that point, and then manually disable that after the billing cycle restarts, but I would like to automate that of course.
If not, I wonder if a future firmware upgrade could add that functionality?
1 Reply
- Blanca_ONETGEAR Employee Retired
Hi TimeFramed
Welcome to NETGEAR Community!
LB2120 can send you an SMS alert if 3G/4G LTE Data Limit Warning and/or 3G/4G LTE Data limit Exceeded.
Here's the reference link:
http://www.downloads.netgear.com/files/GDC/LB2120/LB2120_UM_EN.pdf [page 71]
But there is no option to automatically switch connection if data usage exceeded or reached data usage. You may post your query or suggestion to this page :
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Blanca
Community Team
