askneagain
May 24, 2016Aspirant
Batteries won't charge AC760
The modem is just over 12 months old and has trouble accepting a charge. It will work occasionaly but rarely. I have tried other chargers with the same result. Yesterday I managed to get it to 100% t...
- May 29, 2016
Looks like it is a faulty connection. The battery will charge fine if removed and fitted to a battery charger. The charging leads all work fine with other devices. This could be a fault as this is the second one to do this to me.
askneagain
May 26, 2016Aspirant
Hi I can remove the battery but how do you charge it independantly, isnt the charger 5v or is it ok to use a 12v source?
Also it is a 790S not a (760)
askneagain
May 29, 2016Aspirant
