farukhcasy2
Jul 24, 2020Follower
Best mobile wifi router for car.
Hi,
Could you recommend a mobile wifi router (with LTE support) which could be used in car?
I considered Huawei E5573CS-322 but I'm not sure if leaving a device with a bettery inside of a car is a good idea (especially in summer when temperature can be pretty high). Are there any good mobile routers powered via USB/microUSB but without a baterry and with good tolerance for high and low temperatures?
Thanks!
1 Reply
- icarusponyLuminary
Best? Nighthawk MR1100. You can remove its battery and power with USB.
