MTS04
Nov 13, 2015Aspirant
Bigpond Wi-Fi 4G Advanced 11 stops charging @ 38° C
I have noticed that sometimes the hot spot will stop charging when temp is around 38° C. This doesn't always happen as I have seen it charge properly at 40° C When it does stop charging I have to put ...
DarrenM
Nov 16, 2015Sr. NETGEAR Moderator
Hello MTS04
Have you bulled the battery out and check to make sure its not going bad and warping? You also may want to contact your phone company or netgear phone support if its still under warranty this does not sound like normal behavior.
DarrenM
MTS04
Nov 16, 2015Aspirant
Hi Darren,
Thank you for your reply.
The battery is physically OK. As I said in my original post this does not happen all the time.
Sometimes it will stop charging around 38°C and other times it will reach 40°C and charge fine.
Mostly the operating temperature is around 36°C or 37°C max once it has been on for some hours.
- MTS04Feb 21, 2016AspirantTelstra replaced the modem under warranty and the replacement does the exact same thing. If I connect USB to charge it the charge is not started if temp is Over 37° C. The manual clearly states that charging will stop if temp is 45° C. I shouldn't have to put hotspot on a cold pack to get it to start charging. As soon as the temp drops below 37° C it starts to charge. Not a happy camper.
