Inglorious10Tv
Apr 22, 2020Aspirant
Buying a night hawk m1
So I’m looking to buy a m1 and I was online and on amazon they have them for 400 but here they are around 300. Does anyone know if either one of them come with a plan or are they just the router. I’m going to be using this in a truck since I drive trucks for work and want to have WiFi in the truck for my phone and laptop.
- You will still need a provider, but the device will not be locked to one provider (unlocked)
Then you can get the best provider in you country.
I bought my device for £140 , then I got a data plan for £20 per month
- LexsteelAspirantDevice only unless you buy from a mobile provider
- Inglorious10TvAspirantSo if I buy off of here I don’t have to do any provider this is ready to use right out of the box?
- LexsteelAspirantYou will still need a provider, but the device will not be locked to one provider (unlocked)
