BorisGS305P
Sep 15, 2021Follower
Buying the additional power updater
Hello there,
does someone know where I can purchase an additional power adapter for GS305P?
Thanks for your help.
BorisGS305P
Netgear doesn't sell replacement power supplies. But you can buy them from 3rd party suppliers.
Netgear does not, it seems, sell replacement power adapters. Any generic adapter will work. Just get one with the right volts, enough amps and a tip with the right (+/-) polarity and dimensions to fit your hardware.
The details you need should be on the old adapter, on a label on the device itself and in its manual.
You can find suitable adapters in all the usual places. Some will even list compatibility with different Netgear hardware.
