NikhilAlapati's avatar
Jan 21, 2018
C3000 router crashes every night
my router crashes every night and I look through the logs and I see this
[DoS attack: Illegal Fragments] from 180.193.235.0, port 0
  • Hi NikhilAlapati,
    What process have you already tried to attempt to fix this?
    How many devices do you have attached to the C3000?
    Please proceed with these steps and let me know if the issue has been fixed.
    - Reset/Turn off your C3000 overnight so it can receive a different IP address.
    - forget/disconnect the network on all attached devices and manually connect back
    - If that didn't fix your problem then call your ISP (internet service provider) to have them change your IP.
    - Jason N
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi NikhilAlapati,
    - Jason N
  • JasonN's avatar
    JasonN
    Hi NikhilAlapsti,
    I just wanted to check in and see if these steps have fixed your issue. please let me know. :]
    - Jason N
      • JasonN's avatar
        JasonN
        Hi NikhilAlapati,
        Thank you for your response. I'm glad that this has fixed your issue. Enjoy your C3000 :]
        - Jason N
