chrissy68's avatar
chrissy68
Cable for Unite Explore
I have lost the battery charging cable for my Unite Explore 815S and I cannot find one online anywhere. Can anyone help me find where I can buy one? I need it ASAP because it's for my work and I am about to get in very hot water for having lost it.
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi chrissy68,
    Are you just asking about the cable? If so it is a USB to Micro USB cable that you need.
    Please let me know if this helped you. :]
    - Jason N
    • chrissy68's avatar
      chrissy68
      Thanks for replying!  The cable that I'm looking for isn't your typical USB connection.  The one that I need connects to this opening. The other end will be the USB connection.
      • JasonN's avatar
        JasonN
        Hi chrissy68,
        Thank you for your response. When you are saying "The one that I need connects to this opening", which opening are you talking about?
        Please let me know. :]
        - Jason N
