martinxgarrix
Mar 06, 2018Aspirant
Can anybody please tell how can I login into my netgear router ?
I searched over google to find the way to login into my router settings by logging into 10.0.0.1. But I guess that's for the comcast routers and xfinity routers. Can anybody please tell how to login into netgear router admin settings ?
- JasonNNETGEAR Employee Retired
Hi martinxgarrix,
If you can refer to the NETGEAR KB link below. It is the steps to log into your router.
Please let me know if you need anything else. :]
https://kb.netgear.com/980/How-do-I-log-in-to-my-NETGEAR-home-router
- Jason N
- martinxgarrixAspirant
Sure I will try it out and let you know
Great!
Thank you for responding. :]
- Jason N
- machrit143Aspirant
Thanks for sharing info. My negear router uses 10.0.1.1. how can I port forward 10.0.1.1 to some other ip address ?
- Blanca_ONETGEAR Employee Retired
Hi machrit143,
Welcome to NETGEAR Community!May we please know the exact model of your NETGEAR device? What are you trying to achieve?
Blanca
Community Team
