echeal's avatar
echeal
Can I enable IP pass through mode on an AC340U?
Is it possible to put the AC 340U into IP pass through mode? If so, how?
FYI, the AC appears to have the latest firmware installed: NTG9X15C_01.13.12.14 r18981
Background: I'm trying to use my AC340U (AT&T Beam) with a PocketPORT 2 modem bridge. The PP2 requires the USB modem to be in IP pass through mode. Proxicast (maker of the PP2) has a utility that is perported to put the AC340U into IP pass through mode (see proxicast FAQ ID # 268). Their utility appears to run sucessfully, yet the AC340U fails to actuallly go into IP pass through mode, so it also fails to work with the PP2 (the AC is functional with my PC, but the PC is not getting the real world IP address, it gets a 10.whatever address). It seems the only direct access to the AC340U is via the AT&T AllAccess software, which is really limited (no real access to modem settings, or maybe there is, and it's hidden?). Is there any other way to get the AC into IP pass through mode?
Thanks in advance,  -Ed
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello echeal
    You would have to contact your ISP as they do all the support for this product.
    DarrenM
