lksmr
Jun 16, 2017Aspirant
Cannot login to VEGN2610-1FXAUS (Foxtel Hub) using Netgear Genie software
Hi, Can someone tell me whether there is a version of Netgear Genie Desktop that is compatible with the Foxtel Hub (VEGN2610-1FXAUS). I have tried v2.4.28 and v2.4.38 which fails to login to the ...
lksmr
Jul 03, 2017Aspirant
Hi DarrenM,
Thanks for your reply.
Some time ago I had v2.4.38 running perfectly with access to filtering of individual devices on the network. I did nothing for this feature to suddenly stop working. I didn't update the firmware on the router which was already running the latest available version nor I did update the Genie version on my desktop. If this is the case how would it break? I don't think I can downgrade the firmware on the router as I cannot get the older version which was there originally (I think it was 1.0.0.16). However, is there application support for older versions of Genie Desktop? If so, please let me know the link to download and test older versions. The oldest I have so far is v2.4.28 and it behaves the same as the later version of the software.
Thanks, lksmr
Gavenw
Sep 19, 2017Aspirant
Hi I too have the exact same problem and so far have been unable to find a solution . How did you go with it or is there someone out there with any information thanks
- lksmrSep 19, 2017Aspirant
I have not got a solution from anyone for this problem. I am totally given up on this and not pursuing anymore.
