broof's avatar
broof
Cannot move files to SD card
I tried to enter the model with no luck? It is the Nighthawk MR1100. I cannot put any files on the SD card I put in the router from my computer  ( this SD card did not say that it required a download). The process starts to download put stops and keeps trying over and over again untill I hit cancel.
Thank You!
  • Is it the Telstra version of the M1 MR100 ?
    I noted that the Tesltra firmware doesn't have the shared space allowed on the international version, so media files can be put on an USB or SD and then put in to the MR1100 for streaming to home entertainment,.. and no way to upload the files over the network.
    • broof's avatar
      broof
      It is a MR1100-100 NAS purchased from DirectDial  (recommended by Netgear). I do not believe it is “branded” with anyone but not sure?
      I cannot create a new folder also ( message says an exception during request occurred)?
      It starts to take a file, stops and try’s again and again until I cancel the request
      (drag and drop).
      The SD card is an SanDisk 32 GB. It did not say that it required a download on the package.
      Thank You for your reply.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi broof
    May we please know the exact model of the MR1100 and the current firmware?
    Blanca
    Community Team
