stevenson's avatar
stevenson
Follower
Sep 22, 2015
cannot remotely manage netgear MBR1515A router
The remote address to the router is dead even after "Remote Management" is enabled.  How do I solve this problem?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello stevenson
    Netgear does not do the support for this product you will want to contact verizon for support. But if a recent firmware has came out and it stopped working after a update try to go back to the older firmware and see if remote management starts to work again.
    DarrenM
