lj99's avatar
lj99
Cannot reset my Wireless Network password
For some reason, I can no longer reset my password under Setup/Wireless for either the 2.4 or 5GHz networks. I've done this at least 2 times before successfully. I've tried them individually, and together, and in both cases the red SAVE button is greyed out. Any suggestions?
  • Which router model?
    Whiich firmware version? (not "the latest")
    Have you tried one by one?
    • lj99's avatar
      lj99
      microchip8 wrote:
      Which router model?
      Router:
      Firmware is NTG9X50C_12.06.39.00
      if you mean tried to change one, the back out, then tried the other , then yes
      model = Nighthawk M1 Mobile Hotspot MR1100-100NAS
      apn = Cricket.mht
  • plemans's avatar
    tried a different web browser?
    and a different pc?
    • plemans's avatar
      Also make sure you're meeting the password requirements.
      At least 8 characters. I'd avoid special characters or spaces.
      • lj99's avatar
        lj99
        <<Also make sure you're meeting the password requirements.
        At least 8 characters. I'd avoid special characters or spaces.>>
        all letters & numbers only, already had 8 addedn 6 more with no change
    • lj99's avatar
      lj99
      and a different pc?
      only have 1 pc (hard to have multiple in RV)
      normally use Chrome. worked same on Brave, Firefox is currently crashing 3 - 4 times an hour, and Opera can't seem to find it.
      • lj99's avatar
        lj99
        lj99 wrote:
        and a different pc?
        Tried AVG browser, worked the same (or didn't work, in other words) as Chrome & Brave
