mslsailor
Mar 16, 2021Aspirant
Can't get back into configured and working DM200 modem
I am trying to get the login page of my DM200 modem. It has been running for years in MODEM ONLY mode with an R6400 router. Now I am troubleshooting internet issues with my ISP, and need to confi...
- Mar 16, 2021
Found this solution under another post:
From the manual...
After you disable the modem’s routing features and the modem functions as a DSL modem only, you can access the modem only through a fixed IP address, which is 192.168.5.1.Therefore, make sure that IP address 192.168.5.1 is not assigned to another device on your network. Your routers manual - Page 70.
You won't be able to get to it from the router's. .1.x subnet. Plugging directly into a LAN port with a laptop, on the DM200, launch a browser and connect to 182.168.5.1. FIRST things FIRST. Configure your laptop's NIC card in the 192.168.5.x network - use address: 192.168.5.100 mask: 255.255.255.0. This should get you onto the DM200.
Thank you. Always helps to read the manual.
michaelkenward
Mar 17, 2021Guru - Experienced User
Next time you have problems with the DM200 you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for that device:
DSL Modems & Routers
