Elmer2flp
Oct 13, 2018Aspirant
Can't open port in LB1120
I am unable to open any forwarding ports in my LB1120 LTE modem. If anyone has done this successfully, please tell me ALL the settings. I am using an Acer laptop running Windows 7 and an 8-port switc...
brian_sadler
May 04, 2019Initiate
This is an old known problem and it's caused by your 4G LTE carrier. The IP assigned to you is NOT visibile on the internet so you will not be able to port forward. Apparently is was visible on 3G networks, but not for 4G and problable not for 5G either.
I have 2 installations, one on COMCAST cable and no issues. The other is ATT 4G LTE/LB1120 and I have been unable to access the ports from the internet.
The solution is to request a FIXED IP: from your carrier, but this will cost $500. An alternative is use TEAMVIEWER remote desktop, but you will need to install a server at the remote location. I can't say performance is that great. Mine seems to work only for 30s at full speed and then intermittently after that.
Good luck...
Robokop
May 06, 2019Aspirant
Thanks Brian, I appreciate your response. I had suspected that the issue was related to the carrier as I also had a problem with white listing. I tried to white list my IP in order to access systems in the AWS Cloud but that would not work either. I have since changed the carrier to Tmobile and that solved the white listing issue. I have now requested a static IP from Tmobile. I am hoping that will solve the port forwarding issue.
- RobokopMay 09, 2019Aspirant
I just wanted to provide a final update. I recived a static IP from Tmobile and now everything is working as expected. my port forwarding is working for my video stream from my web camera, I am able to white list my IP in AWS so I can access those systems and my up and download speeds are 3x faster for down load and 12x faster for uploads. That allows me to upload an HD quality video stream. By the way I was told AT&T does not offer a static IP. Maybe that was just through my ISP but my Tmobile configuration definately works.
