cherg's avatar
cherg
Can't update Netgear AirCard AC790
Hello. I can't update software. Always this error.
Software Update Available
A software update is available for your hotspot. Download size: 0 KB. You may incur charges for data used during the download.
Start Download
Update Error
There was a problem updating your device. Please try again later.
How to fix?
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi cherg
    Welcome to NETGEAR Community!
    Please provide the current firmware version?
    You may want to try a factory reset and then try again the firmware update.
    Blanca
    Community Team
    • JohnPeng's avatar
      JohnPeng
      NETGEAR Expert
      Thanks for the report. This may be a misconfiguration for the OTA upgrade.
      Let me check tomorrow and get back to you.
      Regards
