Marian_P
Sep 26, 2025Tutor
Carrier aggregation info on MR6150?
Does M6 5g support carrier aggregation? I guess it is. If so, how many carrier aggregation bands can I use? For example, the Nokia 5G Receiver 5G16-A supports 4 Carrier Aggregation (4CA), allowing it...
- Sep 26, 2025
Its spec sheet here:
https://www.netgear.com/home/mobile-wifi/hotspots/mr6150/
Says:
Carrier Aggregation
Up to 5x Carrier Aggregation on LTE (CA)
Up to 6x Carrier Aggregation on LTE+5GNR (ENDC)
Up to 2x Up-Link Carrier Aggregation
Sep 26, 2025Guru - Experienced User
Says:
Carrier Aggregation
