JamesNnc's avatar
JamesNnc
CC tells me my MR1100 can no longer be supported in 2022
It seems CC's database has determined my device IMEI (015240000217062) indicates a 3G device or a 4G device the networks will no longer support starting in 2022.
Is this true?
  • CC? Comcast? If so, why don't you call them up and ask? We're not experts on what ISPs support and discontinue
    • JamesNnc's avatar
      JamesNnc
      Thanks for commenting, however, my question of course was based on talking to several ISP support people; I received various reason why the MR1100 would not be supported in 2022 when the networks drop support for 3G devices. One said their data base indicated it was a 3G device, one agreed it was a 4G device but would not be supported in 2022 because it did not support Voice over LTE and the networks were dropping all 4G devices without this capability, and one found a list showing the device would be supported. In addition I have found AT&T will be the first to make these changes starting as soon as 1/15/2022 and on their WEB site they have a detailed list of all devices they will support in 2022; the MR1100 is listed there as a 2022 supported device. Not being an expert in this area perhaps you can see why I was confused and ask the question here as well.
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
    Thank you
    Is this true?
  • I have changed my WIFI password and after changing it the previously connected Devices connect autometically why don't ask for new password is any body has solution? UPSers
