PsiTechs
Apr 04, 2018Aspirant
Change APN Type
Bonjour, i am having a serious issue with my Aircard 810s. I bought a secondary cellular number with a secondary Sim Card, just to use it with 4G LTE, and specifically bought the Aircard 810s to use...
- Jun 11, 2018
Hi PsiTechs,
Welcome to NETGEAR Community!
Once you have supplied the APN information then the mobile hotspot checks the APN to determine the type of network connection to establish.
Here's a reference link of how to configure APN settings for AirCard 810:
https://kb.netgear.com/30621/How-to-configure-APN-settings-for-AirCard-810
Blanca
Community Team
PsiTechs
Aug 11, 2018Aspirant
Bonjour, sorry for the delay, i didn't notice the notification of your message until now.
The issue is still troubling me, i know how to create the APN. What i'm trying to do is configure it by adding ",dun" to the APN Type (as shown in the picture added), as i am able to do on cellphones.
The procedure you gave me is just to create the APN but doesn't tell me if it is possible to add ",dun" on the APN Type either from the device itself, or the webinterface.
Is this modification doable or am i wasting time and should change router ?
Thank you for your reply
